FAST BURN 384HORSE IN A 91 Z
Old Jul 6, 2001 | 12:42 AM
Flip71ss's Avatar
I HAVE A 1991 Z28 CONVERTABLE AND I AM LOOKING TO SWAP THE 305 FOR A FAST BURN 385,WHAT WOULD I HAVE TO CHANGE BESIDES INJECTORS TO MAKE IT RUN RIGHT,I ALREADY HAVE A 2500 STALL AND NO EMISSION DEVICES LEFT ON THE CAR ANY ADVICE WOULD BE NICE SINCE YOU GUYS SEEM TO BE PRETTY GOOD AT THIS STUFF.THANKS P.S. SORRY ABOUT THE 384 IT IS SO CLOSE TO THE 5 LOL.
[This message has been edited by Flip71ss (edited July 05, 2001).]
Old Jul 6, 2001 | 10:03 AM
MikeS's Avatar
I might be mistaken, but the fast burn engine would have the fast burn heads, which are designed like the vortec heads. You're car is a TPI, right? Thus, your TPI system won't fit right with the heads on that engine.
Old Jul 6, 2001 | 11:27 AM
Flip71ss's Avatar
I WAS TOLD THAT THE ALUMINUM VORTEC HEADS ARE DRILLED TO USE BOTH OLD AND NEW TYP INTAKE MANIFOLDS IS THAT NOT TRUE WITH THE FAST BURN HEADS I PLAN TO USE AN EDLEBROCK TPI BASE AND RUNNER SET ON WHATEVER ENGINE I PUT IN THE CAR,WILL IT NOT FIT THE 385?
Old Jul 6, 2001 | 12:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Please lose the ALL CAPS function. It's very hard to read, and should be reserved for when you are shouting at somebody.
The ports on the Fast Burn heads are not in the same place as they are on a TPI base. If you simply drill holes, then yes they'll bolt up; but you'll have giant manifold vacuum leaks where the TPI base doesn't cover up the Fast Burn intake ports. AFAIK no one makes a TPI base that will bolt up to those heads, since it's an inappropriate combo in the first place; but it is said (and has been for about a year or more) that any minute now, someone is going to start making one for people that want to do it anyway.
ICON Motorsports
Old Jul 6, 2001 | 12:56 PM
Flip71ss's Avatar
hey thanks for the info i guess i will just buy a short block and run edelbrock heads for a tpi car,but why is the tpi manifold not a good setup on vortec heads(if they fit properly)!
Old Jul 6, 2001 | 01:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The Fast Burn heads are set up for a high-flow, high-RPM, single-plane-intake kind of motor: very lo restriction, lowest possible velocity. TPI is designed to be low-flow and high-velocity for highest possible low-RPM torque. The 2 approaches to intake tract degign are completely at odds. What you'd end up with is the air coming rushing in through the runners at high velocity into what amounts to a plenum behind the intake valve, thereby killing off the "ram" effect of the runner. Since the runners don't flow, you'd have no high-RPM horsepower, and since the "tuned" aspect of "tuned port injection" would be eliminated, you'd lose the bottom end it's supposed to give too. This is a good example of where you might actually slow the car down by upgrading one piece incorrectly.
ICON Motorsports
Old Jul 6, 2001 | 01:47 PM
Tas's Avatar
Tas
you'd have to swap out your tpi for the Mini Ram III or the Holley Vortec EFI unit. the tpis one, www.tpis.com , has the throttle body if front, the Holley one has it on top like the original Vortec trucks. www.holley.com . You can also put on a Ram Jet, www.sdpc2000.com but I don't know if anyone has made it run with stock computer yet.
Mini-Ram
http://www.holley.com/HiOctn/ProdLin.../9901-110.html
www.sdpc2000.com
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited July 06, 2001).]
InfernalVortex
Apr 20, 2021 11:31 AM
db057
Apr 28, 2019 07:45 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
CatmanFS
Sep 19, 2015 09:00 AM
abray1
Sep 10, 2015 04:53 PM
