have305tpi also 350 long block will it work???
Old Jul 6, 2001 | 03:35 PM
gt auto's Avatar
Hey,
I have a 305tpi in my TA I also have a 350 long block (heads down) will everything off the 305 work well on the 350 block?? the tpi setup injectors and all the other good stuff.
Old Jul 7, 2001 | 03:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon the respective years of the TPI and 350 heads. In '87, they switched from all the intake bolts being at the same angle, to the center two on each side being at a different angle. So, if your TPI is '87-later and the 350 heads are '86-earlier, they won't match without doing some elongation of the manifold holes.
Otherwise, the 305 parts will work, but won't be optimum. For instance, the plenum restricts a 305, so it should be ported per the tech article. Also, 305s came with 19lb injectors and 350 22lb, but with an adjustable fuel pressure regulator, you can overcome that. If the 350 is particularly healthy, you might want to go with 22's anyway.
The 350 will move more air than the 305 did, and the 305 exhaust is restrictive to a 305, so headers, high-flow y-pipe & cat as well as cat-back should be considered. It's also said that the ignition curve is more aggressive for 350s, so a custom or 350 chip should be helfful.
Also, in '86 they switched from a two-piece rear main seal to a one-piece design. The flex plates don't interchange, so if yours is '86-later and the engine is '85-earlier, you'll need a different flexplate. If your 350 doesn't have an oil pan, it is different as well for the same reason.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
milk
Aug 10, 2015 06:26 PM
