Need wiring diag. for 92 RS to 94 LT1--PLZ hurry
Old Jul 2, 2001 | 12:19 AM
UnderDogRS's Avatar
i need the wiring changes that need to be made to install a 94 LT1(w a/c deleted) into a 92 RS. im going to put the LT1 in next week. and need to have as little downtime as possable.
tia,
RS
Old Jul 2, 2001 | 09:21 AM
UnderDogRS's Avatar
also im getting the complete motor w/ harness and computer,4L60E Trans and stock 3.42 gears w/ POSI.
so from what i understand i only need to put power and ground the engine and splice in my guages(from a wiring standpoint)
thanks again,
RS
***Coming Soon***
94' Drivetrain w/ rear
!A/C, !air, full hooker exhaust, custom programing
Old Jul 3, 2001 | 02:57 PM
mat89RS's Avatar
this might help you but it's for a 93 lt1.
93 engine ecm wiring diagram
VATS 16 pin
A8| [] [] [] [] [] [] [] []| A1
B8| [] [] [] [] [] [] [] []| B1
Slot Wire Color Description
A1 Orn Power feed from ECM BAT fuse #4
A2 Pnk Power feed from ECM IGN fuse #5
A3 DK BLU Fuel enable signal
A4 YEL/BLK Starter enable relay control
A5 GRY "Security" indicator lamp control
B5 BLK/WHT Ground
B7 PPL/WHT Ignition key resistor return
B8 WHT/BLK Ignition key resistor feed
| | Top White 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is DK GRN and is the coolant temperature feed to instrument cluster.
J is DK GRN/WHT and is fuel pump replay control
H is empty.
G is DK GRN/WHT and is vehicle speed signal.
F is GRY and is fuel pump motor feed.
A is RED and is Alternator feed to instrument cluster.
B is TAN and is oil pressure feed to instrument cluster.
C is BRN and is oil level feed to instrument cluster.
D is empty.
E is empty or if you have a manuel tranny it is the clutch anticipate signal and is GRY.
| | Top Blue 10 pin
|K|J|H|G|F|
|A|B|C|D|E|
K is TAN/BLK and is (Automatic) torque converter clutch control.
J is ORN/BLK and is (Automatic) park/neutral feed from transmission position switch.
NOTE: If this vehicle is manuel the wire would be LT GRN and would be (manuel) backup lamp feed.
H is LT BLU/BLK and is (Automatic) TCC switched power feed.
NOTE: If this vehicle is manuel the would be be BRN and be (manuel) power from turn B/U fuse # 2 to backup switch and would be brown.
G is PNK and power feed from ECM IGN fuse # 5
F is DK GRN/WHT and is A/C request signal
E is DK BLU and is theft deterrent - fuel enable feed.
D is WHT and is techometer signal to instrument cluster.
C is WHT/BLK and is diagnostic request signal.
B is service engine soon indicator feed.
A is empty.
Black Connector 4 pin
|A|B|C|D|
A is PPL and is ignition (crank starter)
B is BLK/WHT Ground
C is ORN Power feed from ECM BAT fuse #4
D is Empty
C100. It connected (on the 93) to the underhood fuse block.
|A|B|C|D|E|
|K|J|H|G|F|
A is PNK and is power feed from injector fuse 9
B is DK GRN/WHT and is A/C compressor relay control
C is DK GRN and is A/C compressor clutch solenoid feed
D is TAN and is serial data signal.
E is BRN and is Air Pump Replay Control.
F is BRN and is power feed from FANS/SOLs Fuse 6
G is PNK and is power feed from ignition fuse 11
H is DK BLU and is secondary coolant fan relay control
J is DK and is primary fan replay control.
K is PNK and is power feed from injector fuse 10.
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Jul 8, 2001 | 02:38 PM
TexasLT1's Avatar
Car: '92 RS
you better plan alot more time for the swap than what you think. it doesnt seem that daunting at first, especially when the engine is mounted in the car and ready to go and you think the wiring is finished, but itf wont fire. then you realizes you still have about another coupla days of work before its ready to go. give yourself more time than you think you will need.
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
Old Jul 8, 2001 | 03:09 PM
multi-tasking's Avatar
I have the service manuel for the 93. If I can scan something for you please hollow... check out mat89RS's posts.... Lots of info there ...
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
