VATS ECM into non VATS car
Old Jul 5, 2001 | 09:04 PM
camaroguy99's Avatar
When I complete my swap of a 91 350 TPI into my '88 camaro what provisions might I have to make in order to bypass/disable the VATS system in the 91 ECM? Will I even have to worry about it since the car didn't have it to begin with? Thanks
Old Jul 6, 2001 | 03:35 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You will have to disable the VATS in the eprom. You will need an equivalent Memcal for a SD car for you limp mode to work. Just have it reburned with VATS disabled.
Old Jul 6, 2001 | 10:33 AM
leirch's Avatar
If your not into Prom burning i'm sure you could convert the entire locking cylinder over, but thats a pain and i would suggest the reburn of the prom.
Just giving an alternative solution.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jul 6, 2001 | 12:57 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
leirch wrote:
If your not into Prom burning i'm sure you could convert the entire locking cylinder over, but thats a pain and i would suggest the reburn of the prom. Just giving an alternative solution.
Hey Brendan.
I take it you don't know where the VATS module is installed, do you?
You have to disassemble the entire dashboard, including the dashboard mounts
to get to the module. Since the mount is welded and riveted on, it is a pretty big PITA. You could cut a hole in the dash mount to remove it, I guess.
I have a spare 89 Formula with VATS, and I wanted to swap the modules because I swapped key cylinders, and I started tearing the dash apart. I gave up after a couple of hours...
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors, custom chip.
[This message has been edited by LeeH (edited July 06, 2001).]
Old Jul 6, 2001 | 07:26 PM
I am planning on burning my own proms sooner or later, but right now I just need the car to start to make sure I did everything correctly. Is there someway to bypass it mechanically without touching the memcal? I know I could put in the correct resistor but what wire/wires controls the VATS? Thanks again.
Old Jul 8, 2001 | 02:34 PM
TexasLT1's Avatar
Car: '92 RS
dont know why it would have taken a couple of hours just to disassemble the dash, everything bolts together and even the VATS is bolted in. it took me about two hours to have the dash apart, take out the VATS, relocate the new one, and have the dash back together.
Old Jul 8, 2001 | 11:47 PM
Well, I have decided to get a ed wright custom chip with the VATS disabled. didn't want to spend that money now but I guess thats the only way around it. thanks for your help guys.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
djmarch
Aug 9, 2015 05:27 PM
