305TBI to 350TBI
Old Jul 5, 2001 | 04:18 PM
doughboy's Avatar
305TBI to 350TBI
Currently preparing to put a 350tbi in my originally 305 tbi bird, what mods are gonna be necessary to make the swap work. I know I will probably need to change the knock sensor, what about chip, will factory tbi be enough? etc. thanks for any help.
Old Jul 5, 2001 | 08:46 PM
rs_guy89's Avatar
Dude, sorry I dont have any answers for you but if you do get some please pass them along to me d2kearney@home.com, and I will make sure to do the same
Old Jul 10, 2001 | 02:19 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
How strong of a 350 are you putting in there? A mild 350 will work with the stock computer and tbi just fine (will have to increase fuel pressure slightly). If you go over the 300hp mark you will need the 454 throttle body to give you enough air to get max hp. Otherwise its just like having a 2bbl carb on a 4bbl car. It will run fine just not make as much horsepower as it could. Same with the chip. It will run just not as well as it could. You will need an adjustable fuel pressure regulator and either a laptop or a fuel mixture guage to tune the fuel mixture. If going over 250hp a high performance fuel pump is a must. Also chunk the entire exhaust it is not suitable for a 4cyl much less a 350.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
[This message has been edited by brharris27370 (edited July 10, 2001).]
evilstuie
Jan 9, 2020 08:29 PM
armybyrd
Sep 21, 2015 10:28 PM
armybyrd
Aug 10, 2015 09:23 PM
Nick89TA
Aftermarket Product Review
Jul 13, 2001 07:26 PM
Mike92
Nov 2, 2000 05:14 PM
