What do I need to get it done right?
Old Jul 9, 2001 | 11:34 AM
blackbelt's Avatar
Right now I have a 91 Camaro RS with 305 and 5 speed. I want to put in an L98 from an 88-92 Camaro and also put in a 6 speed trans from a 4th gen Z-28. Does anyone know if the trans and engine will hook up together ok. Also I know this has been asked before but what exactley do I need to pull from the donor car when I pull the 350 and what should I look for. Please be as specific and detailed as you can(any ideas what it would cost for a good 350) stuff like that. I am having a shop put in the engine and trans for me and I don't want them calling me to say they need something. Thanks all
Old Jul 9, 2001 | 01:25 PM
91z4me's Avatar
If I were you I would look for a L98 equipped corvette. You could get it with a ZF6 transmission and it would be a direct hook up for the engine and transmission.
Old Jul 9, 2001 | 03:42 PM
Tas's Avatar
Tas
the ZF6 is phyiscly bigger and heavier and its harder to install. It also uses a heavy dual mass flywheel. A T56 6-speed from a '93-'97 4thgen will bolt right up to a '86+ 1-piece rear main seal chevy v8.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 10, 2001 | 12:23 AM
91z4me's Avatar
IF you can get your hands on a t56 why not get the 4th gen engine to go with it as opposed to putting an L98 with it. I mean if you think about it if you are going to spend the money why not get the best. IMO the ls1 is a better motor because it is so much newer. I would like to do that but don't have the money, I would like to do a lot of things but don't have the money. If he can afford a t56 I think he should go with the ls1 or lt1, once again IMO.
Old Jul 10, 2001 | 04:13 PM
blackbelt's Avatar
I would love an LT1 or LS1 but I have been told they are extremley hard to put in something about reverse flow coolant or something like that. Also since I am going from TBI to TPI it is already going to be a PITA. I have enough money for a T56 and an L98. Will someone answer my other question? what do I need to pick up from the donor car when I pull the L98. thanks.
Old Jul 10, 2001 | 04:35 PM
Tas's Avatar
Tas
LT1 is easy, LS1 is still largely unknown swapping territory. The LS1's T56 and the LT1's T56 are physicly different from each other so make up your mind before you start buying stuff. Get everything you can from the L98 or LT1 car, the computer and the whole wiring harness and all the emissions stuff.
-Tas
[This message has been edited by Tas (edited July 10, 2001).]
