li. Simple Question .il
Old Jul 16, 2001 | 09:52 PM
johnyIROC's Avatar
My 355 is 90% done. I am getting ready to put it in the car, but I have one important question. Which flywheel/flexplate should I use? The block is:
1980
crate engine
2 piece seal
4 bolt mains
I am hooking up to a 1983 700R4. Will the 1983 LG4 flex plate off my old engine work?
Old Jul 16, 2001 | 09:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yep.
Old Jul 16, 2001 | 10:55 PM
johnyIROC's Avatar
Are you 100% sure? I am so confused, I have heard a million different stories... about how you need the right one to keep it externally ballanced. Thanks for your help!
Old Jul 17, 2001 | 02:09 PM
five7kid's Avatar
A 1980 2-piece rear main crank has the balance cast (or forged) into it on the output flange, and is "internally" balanced. The '86-later 1-piece rear main cranks didn't have that counterbalance on their round flange, so the weight had to be added to the flexplate making it "externally" balanced.
Your '83 engine had a 2-piece, internally balanced crank and no extra weight on the flexplate. Therefore, it will work just fine on your 1980 engine.
So much for the short answer, but that's a 100% sure answer IF the info you provided is correct.
Or, to put it a different way, if your '83 flexplate will bolt up to the crank on your crate engine, it is the right one.
Old Jul 17, 2001 | 06:49 PM
johnyIROC's Avatar
Thanks guys, I think I'm ready to drop this beast in the car!
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
