502 crate and GNX turbo
Old Jul 23, 2001 | 02:43 PM
NHcamaro's Avatar
Will a 502 crate fit in my 88 SC . also are there any camaros out there with a GNX turbo under the hood ?
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
Old Jul 23, 2001 | 05:18 PM
dtpmike's Avatar
yes it will fit. It is the same size as big block's. It is a squeeze, but a lot of people here have big blocks. They are a lot of work.
Old Jul 23, 2001 | 08:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A 502 block is the best way to get cubic inches out of a big block. It's still a standard 9.8" deck height but gets the larger displacement from a 4.5" bore +/-. It's easy to add a stroker crank and get even more cubes. If you go with a tall deck block of 10.2, You'll have to either fabricate your own headers or do some serious floor pan sectioning to get headers to clear.
I considered going to a 502/502 but it's $8500 canadian for a long block and it's not designed to be raced. If I was going to build one, I'd go with a 502 merlin block instead.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
RedLeader289
May 28, 2019 01:47 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Giocio
Oct 1, 2015 12:20 PM
