Starter Problem
Old Jul 23, 2001 | 11:58 AM
89 CamaroIROCZ's Avatar
Starter Problem
Hey, I'm still stuck with this F'in Project!! Anyway, newest problem is that I needed a shorty starter to fit the flywheel. The flex plate is off an 84 305" Z28 it has the 53 teeth. The motor is a Crate motor dated to 86. It has the 2 piece rear seal. Problem is, no starter is working for some reason. Anyone have any suggestions? The guy who is helping me out said that I'm going to need an adjustable starter in order to get it to hit the flexplate. There HAS to be a mini starter that would fit. If anyone knows of any or has done this swap could wriet back i'd appreciate it. thanks
Matt
Old Jul 24, 2001 | 09:07 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
If your block is made for a big flywheel (Staggered starter bolt holes) you will need to drill and tap the other hole for the straight mount starter to use the smaller 153 flywheel.
If it's already a straight mount starter there's a whole bunch of mini-starters out there or you can order a starter for a 95 camaro and get a factory type gear reduction starter.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
