Where can I get an '88 IROC stock crate motor?
Hi guys, I've been researching awhile but can't come up with a definitve answer on obtaining a stock 5.7, 1988 350 crate motor. Would this motor work? Will the stock 5.7 TPI intake manifold bolt up?
http://www.crateenginedepot.com/stor...8-P63C273.aspx
If anyone can help steer me in the right direction I'd be most thankful. My IROC that I've owned for 16 years has finally 'given up the ghost' and I need a new motor. Where can I get a new motor. Thanks a bunch.
Mike
Mike
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
re: Where can I get an '88 IROC stock crate motor?
Mike
Mike
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Mike
Mike
If you go with that engine, you may want to take the opportunity to install a new cam and get some added power vs. your stock setup.
Transmission: 4L80E/4L80E
To the best of my knowledge, GM no longer makes replacement TPI engines. They no longer make the head castings for sure. You can get a roller lifter 350 short block, but not the heads.
You can get a rebuilt. My brothers bought from these guys http://www.rebuilt-auto-engines.com/...01109299967.f1 , one for his '93 C1500 (specified roller lifters, 083 heads), the other for his '92 Suburban (standard swirl port LO5). Both were well done, both still running without problems and a lot of miles. You don't get tin or rear main seal carrier, but they supply the seals & gaskets.
Car: 1988 IROC-Z
Axle/Gears: 3.45
Re: Where can I get an '88 IROC stock crate motor?
More Info on the motor you are looking at: I got this info from Jegs web site.
only 200HP, you probably will not be too happy with this motor
http://www.jegs.com/i/GM+Performance...68758/10002/-1
Car: 1988 IROC-Z
Axle/Gears: 3.45
You would be better off with this motor
http://www.jegs.com/i/GM+Performance...99529/10002/-1
see this post for more info:
https://www.thirdgen.org/forums/engi...te-engine.html
- flat tappet lifters
- 2-piece rear main seal
- low compression ratio
- '86-earlier heads (and pretty poor ones at that)
Thanks for all of the input guys. There's so much to consider and I really didn't want to get a 'dud' motor. I figured that at least a stock '88 IROC motor would give me what I have come to expect from the car and I could add on to it from there. At least with a 'stock' replacement, I know what I have. I had a motor replaced ages ago when I owned my first IROC (1986) with a Jasper rehab and it worked well but I sold that IROC not long after...
I know the car isn't gonna burn up a quarter mile with the stock motor. This IROC is the 3rd IROC I've owned. I've had an '86, '87 (both 305's), and finally this '88 (350) which has meant so much to me over the years. I even kept this car after I bought and eventually sold my old 2001 Z06 Vette. I'm trying to get a good motor delivered and installed for $4000 or less. I'd like to get the best product that I can as I'm not made of money, and these are some tough economic times.
Mike
Mike
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
