help with the engine
I am getting ready to put a new chevy 350 long block with around 400HP in my 1989 RS, that originally had a 305. and i was wondering if i would nead any other parts so it wont overwork or tear up the rest of the parts. It is quite a big difference in horse power.
Transmission: 4L80E/4L80E
Subframe connectors are a good idea. Poly suspension bushings and boxed or tube LCA's & panhard bar.
Check the tech articles for diff upgrades.
You didn't say what tranny you have. If 5-spd, it probably can't handle it if you plan on using more than 50% of those ponies. If automatic, check for TH700 upgrade posts on the transmission/drivetrain forum.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
84z96L31vortec
Aug 20, 2017 12:16 AM
