400 motors/blocks....how much hp are do you have and has it cracked?
Old Aug 3, 2001 | 02:23 AM
89ProchargedROC's Avatar
trying to decide between a 383 and a 406 or possibly 434 and i want to know how much hp you guys are running and if you have had any block problems, ie cracking
thanks
Old Aug 3, 2001 | 04:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
no problems here
ICON Motorsports
Old Aug 3, 2001 | 08:16 PM
BadSS's Avatar
My engine in the SS dynoed 614 horses and I have hit both a 250 shot cheater kit and a 350 horse big shot kit at the same time. All on a 2 bolt block with ARP studs. With no problems. I've built a couple 420s for folks using the 2 bolt 400 "stock" blocks as well. We're kinda cheap that way, but I hold my breath and cross my toes everytime I hit that 2nd kit. Your machine work and build should always be perfect,, but it has to be double perfect and would also suggest getting the block sonically checked if you plan on power levels over 500 horse. I do think the next build I do for the SS, if I continue to run a small block will be using the Dart or World Product blocks.
Old Aug 4, 2001 | 03:01 PM
brettd's Avatar
is there such thing as a short block 400 to swap into the third gen. I have a 86 trans am with tpi and i want to swap it out for more cubes and throw a carb setup on it = )
Drop me an email with you awnser at
brettd@broadcast.net
Brett
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
