TBI 305 to 350???
Old Jul 20, 2001 | 02:44 PM
colincamaro's Avatar
TBI 305 to 350???
what mods have to be done 89 LO3 to a 350. will the stock TBI unit work , can I just swap or is there more to it?
Old Aug 6, 2001 | 07:06 PM
gwman's Avatar
Eveything will bolt on fine including the TBI. Just use your same intake if you are going to use 87 or later heads. Pre 87 uses a different angle on the the two center bolts.
Old Aug 6, 2001 | 07:38 PM
Ragin'87's Avatar
I'd recommend you get a new intake.. Either the Edelbrock or the Holley. I know there is a problem with one of them. Post this on the TBI board. Just make sure you build the 350 w/ a cam that the computer won't puke on.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 76k miles.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
