350 swap
Old Aug 5, 2001 | 10:38 PM
five0beatr Z28's Avatar
350 swap
i have a LG4 305 85 Camaro z28. i am looking at a gmgoodwrench 350 engine rated at "285 hp". how much hp does this engine REALLy make with all the stock 305 stuff up to it? then what if with exhaust (headers, cat, flowmaster), rejet the carb, edelbrock manifold, k&n open element, will i reach that 285 hp or should i not get that engine and save up for a 350 HO?
Old Aug 7, 2001 | 12:31 AM
Hanks1's Avatar
I would recomend going to a shop that builds motors. Gm charges way to much for their engines. I dropped in a .030 over 350 thats around 375 horse and the motor cost me $1800 with the block included. i used my own valve covers,manifold and 600 carb(both edelbrock) and the thing RIPS. you will have to price around and ask about warrenties. i got a 12 month/12,000 warrenty. Screw paying 2000-3500 for a gm motor. Its not worth the money in my opinion. Hope this helps
84 Z28
78,000 miles
1970 350 ci 4 bolt chevy motor punched .030 over to a 355
stock 1970 heads with 1.94's and very mild porting
edelbrock rpm cam,intake, 750 4barrel
weisco 9.6/1 pistons & rings
edelbrock headers and catback (without the cat)
700r4 trans
3.23 rear (no posi yet)
Old Aug 7, 2001 | 09:52 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
I plan on building my own ZZ4 type motor.It will cost less plus i can build mine with the hot cam performer rpm airgap and better heads for about half the cost of a gm crate engine.
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
theshackle
Aug 22, 2015 06:52 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
