Engine removal with convertor attached??
Old Aug 14, 2001 | 06:06 PM
Blown_n_Injected's Avatar
I am getting ready to remove a seized 305 engine from a 92 Trans AM. The crank will not turn at all to allow me to remove the flexplate to convertor bolts. Can I pull the engine with the convertor attached while the tranny is still in place? Is there enough clearance to move the engine forward enough to clear the shaft?? Should I just pull them together and separate them outside the car. I was originally trying to leave the trans in.
B&I
Old Aug 14, 2001 | 06:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll probably have to pull the rad anyway. Make sure the AC condensor is moved also. For added clearance pull the water pump and whatever accessories are on the front of the engine. After that there should be enough room to pull the engine with the converter attached.
If you drop the tranny crossmember there's no reason you shouldn't be able to pull both at the same time. You'll just have to angle the engine up as you pull it out.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 15, 2001 | 09:05 AM
mvftw's Avatar
I also pull the engine & tranny together. It's easier then bolting them together under the car.
Old Aug 15, 2001 | 08:42 PM
Thanks, I'll let you know what happens. I too have pulled them together before...but never just the engine and convertor in an F-body.
Thanks guys!
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
3rdgenparts
Aug 8, 2015 07:09 PM
