When is a forged crank necessary?
Old Aug 17, 2001 | 10:43 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I will be getting more than likely a 383 and super ram. Will be using a LT4 hot cam (1500-6000 RPM range). So lets say I use a rev limiter for 6000-6500 rpm.....should I get a forged crank to be on the safe side? Or can I get away with a regular cast crank? I will probably eventually use a small shot of nitrous to top it off (100hp).
Old Aug 17, 2001 | 01:06 PM
Chronos_Titan's Avatar
Spending the 600$ on a forged crank on an engine like that is a nessacity. Plus this allows you to internally balance the engine. I have you and I do not regret the move. A cast crank is only good to about 400 hp. The forged one should be good to around 650. This is with regular 4340 steel that most aftermarket street cranks use. If you can go ahead and drop 3000$ on a Crower that will take basically infinate abuse then do that.
84 Z28 383
Stripped w/Cage back halved w/ladder bars and coil overs and 9 inch
700R-4 3.73
I would have a time by now if I could ever get my car back from the shop!!
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
