400tpi swapout
Old Aug 19, 2001 | 04:32 PM
HARDWORK's Avatar
400tpi swapout
I have a sbc400 to put in my 87 IROC.it has a 350tpi/350 turbo tranny.what parts can i reuse to save a few bux?can i use the flywheel,starter,balancer,etc...from the 350?also,which is the best head between the 350 centerbolt and the 305HO?thanx for all replies!!
Old Aug 19, 2001 | 11:18 PM
mat89RS's Avatar
I would say that your 400 sbc will be limited by that TPI, I would suggest to bore it and get bigger runners and injectors.maybe a 58mm trottle body would help.
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
next mods:
crane roller rockers 1.6
lt4 hotcam kit
airfoil
58MM edelbrock trottle body
new paint (wet look blue)
17' rims with 275 zr 40 and 245 zr40
Old Aug 20, 2001 | 04:08 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You can't use the starter, the newer 350's have a straight bolt pattern for a 153 flexplate.
Can't use the 'flywheel' (felxplate) because the 400's are externally balanced. Need a 400 harmonic balancer also.
Old Aug 20, 2001 | 08:58 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't you just love double posts?
Thunder1973
May 4, 2011 12:54 PM
Bobby_80s
Wheels and Tires
Oct 19, 2009 09:24 PM
2kblackgtp
Mar 12, 2007 10:43 AM
techno101
Feb 22, 2006 10:38 PM
Tmony69
Mar 4, 2003 03:46 PM
