L03 stock, Head swap question
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
OK, '89 RS Camaro 305 TBI / 700 R4. The engine is mostly stock, only engine mods are March Powertech pulleys(2 piece) and a Open element K&N filter, Hypertech fan switch and thermostat.
I want to swapout the heads and intake.
I was wanting to bolt on an Edelbrock performer intake, and also I picked up a set of stock 416 heads. These heads came stock on 305 TPI engines right??????
Would these even make enough difference to mess with, and would I have to change the stock PROM tune?
Things I should watch out for?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What other mods do you have? You should really consider a full exhaust from the headers back before you do any other mod. Those mods are needed to support all others. A direct 416 head swap isn't worth it unless it is ported. Check out the stickies above (TPI vs TBI head flow).
Car: 1989 Camaro RS
I do have a high flow cat, 3" exhaust, and a Magnaflow muffler. I would be installing headers also.
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Also note the 416s will need the pre 87 intake. Wasn't sure if you knew.
Car: 1989 Camaro RS
Alright, so say I don't swap heads right now, What would be a good cam that I could install? Lift will give me high rpm power and duration is the low end power, or do I have it backwards? and I have no equipment to do the DIY PROM at home, so whats I good option here? Also, thinking of swaping to TPI later.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
*usually* the higher duration the more high rpm oriented it is. Go with a cam in the 200-220 duration for a mild street build on that motor imo.
Go with lift around the maximum for stock heads (460-480). That's at the rockers btw. If you go any bigger than that you will have to have the valve guides cut down.
As for a cam swap any cam you swap in will need major tuning from what i've seen and heard.
Although if you're looking for a reccomendation i'd email comp cams and see what they think, they will probably email you a reccomendation for a comp cams xfi cam with similar lift and duration to a comp xe262.
Car: currently thirdgenless!!!
I have the exact set up your talking about (check out sig). Heads and intake. It is NOT a direct bolt on. Keep that in mind. If I were you I would either get some 081 heads or use the 416 heads with a carb intake with an TBI adapter. That may require some work on the throttle cable and cruise control cable. They may be too short with the TBI adapter.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
