Swapping in another engine? 350?
Car: 1990 IROC-Z
Transmission: 700-R4
My car (supposedly) has 145k miles on it, and the engine still seems to be running strong...however you can never be too careful with these things. If I ever had to get another engine, what engines could I swap in? (I talked to a guy with an 82 Z-28 who swapped in a 350 from an 84 Corvette...claimed the car ran a 13.1 et)
How much would other engines go for? (used, new/crate, junkyard)
305IrocZ28- Al
1990 Iroc-z 305 TPI auto, Flowmaster exhaust, 2 Rockford 10'' Punch woofers w/ 160a2 amp, 2.73 rear (1650 rpms @ 60mph)
305IrocZ28- Al
Transmission: 4L80E/4L80E
I just turned over 142k on mine. I'm hedging my bet by running sythetic oil in it to keep it from wearing out any more than it has. I changed intake valve stem seals and intake gaskets, oil consumption dropped dramatically. High-mileage SBC's can last a frustratingly long time when you're looking for an excuse to put in something more powerful.
I seriously doubt that "guy" put that '84 Vette 350 in stock and just started clicking off 13.1's - he did a lot more to it before that started happening.
As for what you could put in it, any '87-later style used, new/crate, or junkyard engine could be swapped in. You could create your own with a World Products Merlin 434 CID short block, put on AFR heads and a healthy cam, Bigmouth or Miniram, headers and good exhaust all the way back, connect the subframes and get some gears, do all the standard tricks (injectors, AFPR, chip, tranny beef-up, etc.) and be in the 12's.
Price would be around a grand to reside in the 14's, several thousand to get into the 12's.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
I would have some doubt about a guy who's making 13.1 with a stock 84 corvette engine. he had to modify something to ran that fast .
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
next mods:
crane roller rockers 1.6
lt4 hotcam kit
airfoil
58MM edelbrock trottle body
new paint (wet look blue)
17' rims with 275 zr 40 and 245 zr40
LT1 POWERED
HEADMANS HEADERS
NEARLY 300 HP.
next mods:
lt4 hotcam kit
airfoil
Don't think that 305 has had all of its miles yet, mine has 197,509 as of today and burns about a pint of oil between oil changes. It just needs valve seals. I am currently building a $2000 383. It has an Eagle stroker kit, roller cam, ported and polished heads, and roller rockers. If you can do the work yourself you can save about $2000.
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I beleive an 1984 Vette came with a 305. I'm not sure of the induction type, but it was the first year w/the C4 body.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood,Original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported Plenum, March Power/Amp Pulleys. (???HP)
DIRECT LINK TO PICS OF MY CAR. NO WEB-PAGE. http://community-2.webtv.net/MZavraz...A90/page9.html
1990 Formula
<font face="Verdana, Arial" size="2">Originally posted by PONTIMANIAC 90:
</font>
</font>
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
