help it's an emergency!
Old Jan 23, 2010 | 08:40 AM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
Just had my lt1 boult up by a machine shop..finally started the car and went to take out the water temp sensor and oil and water came pouring out..I don't think it's a head gasket everything is brand new..could the oil cooling lines that go into the water pump and radiator cause this? Please help
Old Jan 23, 2010 | 10:06 AM
Pocket's Avatar
Car: 91 Trans Am
Re: help it's an emergency!
Take it back to the shop
The oil cooler runs coolant to the filter adapter to lower the oil temps to that of the coolant. No oil will mix with the water unless the adapter is damaged
Either they screwed up the build or the adapter. Its their dime regardless of the cause
Vintageracer
Jan 10, 2020 05:33 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
jj4
Oct 9, 2000 01:31 PM
