is there a way to make 88TPI intake work on 86-below heads
Old Aug 28, 2001 | 11:31 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
i got a 1988 TPI setup for my 82 T/A. but the heads are 86-below version..is there anyway to make an 88 TPI intake work on 86-below heads? is there a place that drills them out? or am i going to have to buy a 86-below intake
thanks
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000, 1.5" Jamex Lowering springs(pics are before lowering springs, ill get new ones soon).
For Pictures go to
http://www.geocities.com/red82ta57l/mycarpics.html
A cool Trans Am site with Message Boards http://www.transamgta.com
Old Aug 28, 2001 | 11:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can't say I've done this, but having an '87 intake and '86 heads, I can see how it would work (like many have said) to simply elongate the holes with a rat-tail file so the bolts will line up with the heads. The bolt heads won't mount flush to the intake, so you could have the intake bolt surfaces machined to be parallel to the gasket surface, or make angled washers/bushings to go under the bolt heads. Or, leave them as they are.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 29, 2001 | 09:59 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Been there, done that. I used a rat-tail file (man it's a long job without a power grinder) and it works fine. Just make sure you use large washers, possibly some angle cut ones to hold a little better.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
89mulletbird
Aug 12, 2015 07:08 PM
