The engine is finally back in!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's only been 3 months since I blew up the last engine. I wasn't in a big rush to get this one finished but it's finally back in.
The new Merlin heads look nice however there seems to be a slight fitting problem. They state that the exhaust ports are in the stock location but I found the headers now sit higher. The driver side header now hits the steering column. I heated it up and expanded the dimple that was already there to clear the column. It didn't help the ceramic coating in that spot but I needed the clearance. The passenger side header needed the firewall massaged again so it could go up higher. It's not a big problem but could have been if the proper tools weren't available to do the modifications.
In one week, Sept 15-16 it'll be our last race of the season. Weather permitting, I'll finally be able to get back to the track and see how much better the new engine is. I'm shooting for a 10 second time slip now. I'm still working on exploding the 10 bolt to be guarenteed the hard luck award again this year
After that it's winter project time until the track opens again in May
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: '82 Z28
If that 10 bolt goes, make sure you get pictures
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
'82 Z28
