Did some research and on the fence for an engine package
Old Feb 3, 2010 | 05:51 PM
chevy8788's Avatar
Hey guys, just joined the forum. I actually don't have a Camaro, I have an 87 Silverado 2wd truck but from what I read, this is the forum with all the knowledge regarding TPI and TBI setups.
I am currently running a tired 305 LO3 with a few bolt ons (true duals, injector spacer, TBI spacer, open element). It is backed by a 700r4 on its last legs. I plan on having it rebuilt when I do an engine swap.
Here are the engine packages I am considering and what I learned about each. The L31 Vortec. A regular LO5 equipped with L98 heads and good cam. Or, my neighbor's 305 complete TPI engine.
The L31 looks like a great package. Buy it from GM you get a nice warranty and of course great flowing vortec heads. I would leave the cam alone on this package. Cons include expensive TBI adapter and needing someway to plumb egr, costing more time and money.
The LO5. From what I hear, this engine equipped with L98 heads and a good cam, yields great power and probably costs less than the L31. No adapters or EGR plumbing needed.
My neighbor has a 79 camaro that has a complete swapped TPI 305 setup from I guess a newer camaro. Hasn't been started in years but I remember when it was started with open headers it sounded built. He wants to sell it since he is swapping in a 572 I'll have to ask further details about the specs. It's complete with computer, harness, etc. In this case, I am with a 305 which can be a negative but, since it's complete with TPI injection, I would probably use that, of course I would need a TPI pump but it is a better package over TBI anyways. This is the only way I would run the TPI system. If I go with those other engines, I would stick with TBI. Also, throttle bracket would have to be modified as well as fuel lines, which can cost some fabrication time and money. Something to consider.
What I am looking for, with whatever I decide is something that delivers more power than my weak LO3 (which I'm sure they all would), good mpg, and the least amount of heavy modification.
Old Feb 3, 2010 | 06:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
We need to be careful about keeping this applicable to 3rd gens per Board rules, but back in '04 my brother got a rebuilt L98 long block and put his LO5 stuff on it, along with some Pacesetter headers and a TB spacer in his '93 1500. He loves it. Since you're starting with a 305, you'll have to find TB and ECM for an LO5 if you want to go that route. Shouldn't be too expensive.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
