What type of motor should i put in my car
Old Sep 19, 2001 | 01:50 AM
superman46's Avatar
I have a 82 berlinetta its has bought a 130, thounds org miles on it. and its time for a new motor now i like the zz4 kits but i want some other ideas thanks
Old Sep 19, 2001 | 02:30 AM
Jester's Avatar
Moved to the Motor Swap board.
Old Sep 19, 2001 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you can swing the HO 350 conversion kit with the ZZ4 in it, you can't do much better than that for having everything you need - assuming you have a carbed V8 auto in the car now. It has a CARB exemption for California.
About the only critism of the kit is that it has cast iron manifolds instead of mufflers, and the price. Lack of subframe connectors another possible nit.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 23, 2001 | 12:11 AM
hiker's Avatar
<font face="Verdana, Arial" size="2">Originally posted by superman46:
I have a 82 berlinetta its has bought a 130, thounds org miles on it. and its time for a new motor now i like the zz4 kits but i want some other ideas thanks </font>
well heres what i did in my 84 bird but of corse im in WV just forget that zz4 stuff and slam a 383 stroker with two big 850 double pumpers i can promise it will zigg you down the road ( you can do so and still remain legal in the state of ca they have air control kit that will work to pass Emmions inspections a freind of mine in pittsburg passes with fling colors in his iroc)
Old Sep 25, 2001 | 12:39 PM
five7kid's Avatar
Two 850 DP's? Riiiigggghhhhhtttt.....
"Air control kit"? They have this nasty habit in California of opening the hood and looking for little things like missing factory equipment and non-CARB exempt parts. The BS detector is pegging here...
Super, if you go with anything other than the HO conversion kit, you'll need to retain all of your stock equipment (except for legal replacement parts like intake manifold and headers). But, it can be done with either a 350 or 383, just keep mum when you go in about it being something other than a 305.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 26, 2015 04:59 PM
slade5612
Aug 11, 2015 07:19 PM
