165 hp to 350+ hp!!!!
Old Sep 24, 2001 | 03:12 PM
five0beatr Z28's Avatar
I got a few qustions about this setup im thinkning about. my car is an 85 Z28 w/ a LG4, auto...blah blah....i want to put in a rebuilt 350 w/ 350 hp, and a turbo 350 transmission. i dont know much about th350s, but will 3.73 gears work well with it or should i go with gears more like 3.42? ive heard w/ 373s and no OD, it will top out at like 100. is that true? the car wont be a daily driver, but i still plan on taking it on semi long trips ( 80 miles @ an average cruise speed of 40 ). well thanx in advance.
Old Sep 24, 2001 | 05:57 PM
Guest
Guest
Posts: n/a
Why dont you just use the tranny thats in the car now?
Old Sep 25, 2001 | 10:23 AM
Damon's Avatar
I'd almost never recommend removing an OD trans and going back to the old-tech TH350. It's a pain to put in a trans that was never designed for the car in the first place and it's really no better than a 700R4 in terms of strength anyway. One time I'd recommend it: for a strip-only drag car. Other than that, forget it.
And 3.73s on the street without OD is miserable. An 80 mile trip at 40 MPH? For real? Not me baby. 80 MPH on an 80 mile trip is how I do things. And you will NOT be cruising at 80 MPH with 3.73 cogs in the back end. Even at 60 you'll be spinning the guts out of the motor pretty bad.
WITH OD, however, 3.73s are livable.
Old Sep 27, 2001 | 03:06 AM
jijiandfarmgang's Avatar
Hey,
Ive got 3.73 with a 350 and th350. Dont even plan on going on the Highway. 80 thats a joke unless you want to redline. Im probably goin 50 at 4000 rpm. Very bad gas mileage also.
Old Oct 2, 2001 | 03:51 PM
812MANY's Avatar
<350/TH350/3.42 65MPH cruise is about 3,000RPM 10MPG. If I drop it down to 2500RPM (about 45-50) just above the stall of my converter I get 20-25MPG.
Old Oct 2, 2001 | 04:55 PM
Just to give you an idea with the 350 3:73 combo. I can let my car idle (around 1500 rpm) and it will shift into second.
Old Oct 2, 2001 | 07:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They used to build cars like that all the time.... I had a 79 Z28, 350/4-speed/4.10s; another Z28, a 78, 350/350/3.73s (that was the stock combo in the 78); I have a 74 Caprice convertible, 454/400/3.42s.
Sounds OK to me.
ICON Motorsports
Old Oct 2, 2001 | 07:36 PM
HARDWORK's Avatar
I agree.I have seen quite a few th350/3.73 combos,especially if it's not your daily driver.I have 4.10's in mine,I can cruise but forget the interstate!later
"Let's get to it,well let's do it!"
Old Oct 2, 2001 | 10:48 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
what do you mean a TH350 isnt stronger?
Wide Open Till You See God...Then Brake
Old Oct 3, 2001 | 03:30 PM
Damon's Avatar
No, stock for stock it's no stronger than the 700R4. They are weak in different places, but overall, about the same strength wise.
Old Oct 4, 2001 | 12:05 AM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
<font face="Verdana, Arial" size="2">Originally posted by five0beatr Z28:
but i still plan on taking it on semi long trips ( 80 miles @ an average cruise speed of 40 ). well thanx in advance.</font>
Don't you mean 40 miles @ an average cruise speed of 80?
69GTOby
Apr 18, 2016 02:34 PM
C409
Jan 21, 2016 08:29 PM
sreZ28
Oct 22, 2015 08:21 AM
jerflash
Sep 24, 2015 03:11 PM
ezobens
Aug 19, 2015 10:29 PM
