350 blocks
Old Feb 9, 2010 | 09:41 PM
Fullofquestions's Avatar
350 blocks
Whats the difference between a 1985 350 block and a 1991 350 block. The only thing that I know of is the rear main seal. Do the same heads fit both?
Old Feb 9, 2010 | 10:18 PM
89fireeagle's Avatar
Car: 89 firebird 83 t/a
Engine: 305 tbi
Re: 350 blocks
im pretty sure they should. look at the bolt patternt they will tell u
Old Feb 10, 2010 | 11:33 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 350 blocks
they will both use the same heads without issue. depending on where the block came from, the newer one may have provisions for hydraulic roller lifters as well
Old Feb 10, 2010 | 01:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 blocks
Any SBC heads will bolt to any SBC block. The crankshaft flange and oil pan are the major differences.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
