305 to 383 stroker
Old Feb 10, 2010 | 02:29 AM
Fordkilla84's Avatar
Car: 84 Camaro
Engine: 383 stroker
305 to 383 stroker
Ok i am ordering the full 383 stroker motor off of the jegs website it has 405 hp and 440 torque. I was wondering what all do i need 2 upgrade in my stock 84 Camaro to be able to run this beast like it needs. I am also ordering a new starter and aluminum radiator. Any advice on cooling or anything else i need will be appreciated
Old Feb 10, 2010 | 04:46 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: 305 to 383 stroker
It should just bolt right up without any problems. Cooling should not be a problem either because it's only bored .030 over. Did you buy the dressed kit? Because it is a true turnkey motor as long as you all ready have a 1 piece rear main seal motor now.
Old Feb 10, 2010 | 07:17 PM
Car: 84 Camaro
Engine: 383 stroker
Yes I bought the dress motor. Im just worried about the rear end and cooling. And if the tranny will be able to take the horsepower. And where I am going to be able to find the parts that i need!
Old Feb 11, 2010 | 06:30 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I would get a transmission rebuild with a new performance valve body kit installed. Try and find a Z28 and get the rear end out of it. That should hold up OK.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Gambit TA
Sep 1, 2015 07:27 PM
TEEZER TA
Aug 30, 2015 06:35 PM
