3.1 to carbed V8
Old Oct 2, 2001 | 10:48 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
3.1 to carbed V8
will i need to keep the computer if i go with a non-computer-controlled carb?
what do i do with all the excess wiring?
i'm not worried about emissions testing becuz i have some hook-ups..................
but..........what i want to put in is a carbed 383.............i'd probably build the motor myself...........what would i need to do with the fuel pump?
could a single fan handle this motor or is a dual fan a better option?
for a 383 with say, ported heads, 11:1 compression, and an edlebrock intake, big cam, what would the best carb for it be?
Slayer of the following:
1996 Riced-out Honda Civic (all show and no go!!!!!!)
2000 saturn
198? Ford Crown Vic, (no i don't know why he bothered)
1990 Buick LeSabre 3.8
1986 Camaro 2.8
Newer Ford Explorer
Food that makes me sick: RICE
1991 Camaro RS 3.1 V6 5-speed
1991 Z28 Rims with Firestone Firehawks
dual snorkel intake w/ slashed boxes, 2 K&N's, 180* t-stat, 80 series Flowmaster (sounds AWESOME)
my motto: I CAN'T DRIVE 55
Old Oct 2, 2001 | 02:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you have a non-CC carb & distributor, the computer will be brain dead. Doesn't hurt anything being there; SES light will come on, that's all (take the bulb out).
After you get it running and are sure everything works, cut out the excess wires, rewrap what's left.
Fuel pump, either get a 3-port regulator to bring the pressure down to 5-7 psi; or remove pump from tank, put in a piece of hose in its place (or a non-in tank pump pickup), and plumb a line over to a mechanical pump on the front passenger side of the engine.
Dual fans is the better option.
A 750 cfm should handle a 383.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Oct 3, 2001 | 09:32 PM
yeah
when the computer is "dead" though
what will control my fans to come on and etc?
do you mean just dead to the engine or what?????
Old Oct 4, 2001 | 08:52 PM
five7kid's Avatar
Convert it to a switch in the passenger side head.
Old Oct 6, 2001 | 12:18 AM
what else will need to be done?
i know i gotta move brake and fuel lines
(and the obvious stuff: tranny, radiator, springs)
Old Oct 8, 2001 | 06:32 PM
thatsme's Avatar
I did the same swap. To use my fan i found the wire that originally went from the sensor on the v6 head and grounded it. You don't have to mess arougn with running wires you can uses the ones that are already there. If you want to use a switch make one up that grounds that wire. You can get away with much smaller wires and switch since you are only activating a relay.
Old Oct 9, 2001 | 12:27 PM
<font face="Verdana, Arial" size="2">Originally posted by thatsme:
I did the same swap. To use my fan i found the wire that originally went from the sensor on the v6 head and grounded it. You don't have to mess arougn with running wires you can uses the ones that are already there. If you want to use a switch make one up that grounds that wire. You can get away with much smaller wires and switch since you are only activating a relay. </font>
cool, thanx for your help
was there anything else you had to change or was that about it really??? how will i set up the choke on the carb?
Old Oct 11, 2001 | 09:40 PM
anybody?
also i heard that i will need to get a 350 block clearanced to fit the 400 crank.......is this true???
what about my brake lines??? do they NEED to get moved?
what accessories that my current V6 has can i keep?? what will i need new brackets for?
i guess i'll need a new starter and a balancer and a flywheel
what kinda carb should i get? manual or electric choke?
Old Oct 12, 2001 | 03:06 PM
five7kid's Avatar
The block will have to be clearanced on the pan rails for the rods. For a 383, you'll need externally balanced flywheel/flexplate and harmonic damper.
You must move the brake line on the front crossmember because the V6 line sits right were the V8 mounts need to go.
About the only accessories from the V6 that will fit are the AC compressor and power steering pump, and even those will need new brackets and hoses.
An electric choke is so much less hassle than a manual on the street. If it is only started at the track, then perhaps you could justify a manual choke.
Old Oct 13, 2001 | 01:26 AM
thanx alot, man
thanx for clearing up the question about the brake lines
i mite just go with a 350 since i wanna start off with a brand new block
either way........how are Tremec trannys?
some dood at work said they are great and would work good
any other stuff need to get changed?
vacuum lines anything?
so far here is ALL i know that needs to be changed:
TRANNY, RADIATOR, MOTOR MOUNTS, BRAKE LINES, SPRINGS, FUEL PRESSURE REGULATOR
if so this doesnt seem 2 bad
now, not to ask a dumb question, but the computer in my car only controls my fuel injection/ engine........when i "kill" it, it won't effect anything else, right?
Old Oct 13, 2001 | 03:59 PM
PlayBoy's Avatar
Somethin to add to your list is longer drive shaft and torque arm !! the Th350 tranny is shorter than the 700r4 tranny You also might need a tranny mount kit to do this. Ive just started this swap too so good luck 2 ya
Old Oct 13, 2001 | 10:47 PM
<font face="Verdana, Arial" size="2">Originally posted by PlayBoy:
Somethin to add to your list is longer drive shaft and torque arm !! the Th350 tranny is shorter than the 700r4 tranny You also might need a tranny mount kit to do this. Ive just started this swap too so good luck 2 ya </font>
uh well, i meant a 350 instead of a 383
my car will always be manual
i am thinking about going with a Tremec 5 speed
thanx for the good intent though
we need more of that nowadays
RedLeader289
May 28, 2019 01:47 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
