305 LG4 to 350 swap
Old Oct 15, 2001 | 05:07 PM
tennysonmr's Avatar
305 LG4 to 350 swap
I have an '87 Formula that had the 305 LG4 and T-5 tranny. A basic 350 was recently installed using the stock LG4 intake manifold and carb. Do I need to change out the ECM? Are there any other changes I need to make to ensure a smooth running car? Thanks in advance.
Old Oct 16, 2001 | 12:08 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Well you should go to a knock sensor and the module to go with the sensor that are made for a 350, I am not sure of the correct part number though. You can go for a chip if you like it is not really needed though. I did and I did notice a slight diffrence. I am still runing the stock fuel pump but I am liiking into getting a diffrent one.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 16, 2001 | 07:34 AM
Damon's Avatar
Your stock ECM will run it just fine, actually. It's a computer controlled carb, not FI and the carb self-adjusts to whatever engine it's on about 80% by itself. It only knows airflow, not what size engine it's on top of.
I would highly recommend upgraded the secondary rods in your carb to a set of "DR" rods (in place of stock CH or DP rods) and a "G" secondary hanger. Stock LG-4 calibration is too lean for a moderately strong 350.
I don't know what knock sensor you'd use to replace the stock one. 3rd ben carb motors and ECMs only ever dealt with 305 cube motors, never a carb'ed 350. So there's no obvious replacement to use that I am aware of. Someone else could have better info, though.
I reinstalled the stock 350 TPI knock sensor in my brother's 87 TA when we upgraded to a 400 engine recently and it works just fine despite the fact that the 400 block is quite different than the original 350. So I wonder if all this talk about "matching the knock sensor to the engine" isn't mostly unnecessary.
Old Oct 16, 2001 | 12:08 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Talk to Ken Casey at Burt Chevrolet in Denver,Colorado.He's done tons of these swaps and was very helpful. I swapped out my 305 TBI motor for a 350 and he sent me the 350 Injectors,Knock Sensor and Module for a package-deal price.I'm sure he can tell you if anything else is required for your swap.
(303) 761-1286
Ask for him in the parts department.
I got his name from Chevy High Performance Magazine.
Old Oct 16, 2001 | 01:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
In the ZZ4 conversion kit, the parts lists includes: "Sensor, Knock" p/n 10456288; "Module, Elec. Spark Control" p/n 16128261.
It also has: "Controller, ECM" p/n 1228079; "Calibrator, Prom 1985-87 LG4, 83-86 L69" p/n 24502456. But, those are for automatic cars (have heard will work fine with manual).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
