engine mounts
Old Feb 16, 2010 | 03:12 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
engine mounts
im putting a 400 into my 1989 camaro and i was told that the 87 and older motors had different mounts then the 88 and newer cars, so im wondering where to get them and how to tell the difference? thanks Ty.
Old Feb 16, 2010 | 03:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: engine mounts
Motor mounts are the same.
Old Feb 16, 2010 | 05:59 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Re: engine mounts
there is no difference in solid or poly? they bolt up the same?
Old Feb 16, 2010 | 09:29 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: engine mounts
Solid mounts are for race cars that make massive torque and power. You really don't want that in a street car because it will vibrate your teeth out. Normal motor mounts will hold your engine in place. No need to do anything else.
Old Feb 18, 2010 | 02:21 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
Re: engine mounts
The stock mounts are all the same.
The stock rubber mounts will eat up the most vibration and engine movement, but they also have the most power loss. (If you don't have a wicked suspension and poly bushings all over the car you aren't gonna gain much with anything better than the rubber stuff anyway. Your sloppy stock suspension will disperse your power anyway.
The poly mounts sit just a litte bit higher than the stock rubber mounts. They are a stiffer than rubber, but they still give some.
The solid motor mounts have no slack/give and thus no power loss. Thats why they run em on drag cars. But all the harmonics of the engine are put into the car. Everything rattles.
Old Feb 18, 2010 | 03:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Tyrel2018
i was told that the 87 and older motors had different mounts then the 88 and newer cars...
You don't belong to a liar's club, do you?
You can bolt in a big block with the same mounts and bellhousing.
Old Feb 18, 2010 | 07:42 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Re: engine mounts
ok well i was told that pre 88 motors have the rubber mount on the block and that the 88 and newer blocks had the rubber part on the k member and that there were different motor mounts that i would have to buy because i was putting a pre 88 block in my 89 camaro. im not trying to lie or anything i was just asking because it didnt make sense to me and i was just makeing sure that there wasnt anything special that i would have to buy
Old Feb 18, 2010 | 08:55 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: engine mounts
Originally Posted by The Devastator
... but they also have the most power loss. (If you don't have a wicked suspension and poly bushings all over the car you aren't gonna gain much with anything better than the rubber stuff anyway. Your sloppy stock suspension will disperse your power anyway.
Now let's put this into perspective. How much "power loss" are we talking about here? It's statements like this that make impressionable kids waste money on useless parts.
Old Feb 19, 2010 | 01:28 PM
Car: 1992 Camaro RS
Transmission: WC T5
Re: engine mounts
I Doubt anybody knows exactly how much wheel torque is lost with rubber mounts. Thats why I tell people unless you are committed to upgrading every bushing on the car to something harder than rubber its kind of a lost cause to get all wrapped up in motor mounts. And If you do that you still have chassis flex if you don't cage the car.
That's why the forum is here. So we call all share experience and help each other with our projects.
I've never seen that but I haven't seen everything. Have you looked at the motor mounts you have?
Old Feb 19, 2010 | 01:29 PM
five7kid's Avatar
im not trying to lie or anything...
I was referring to what you've been told by others.
Perhaps it's your advisers who belong to the liar's club.
Old Mar 31, 2010 | 09:59 AM
rojas1826's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
Re: engine mounts
i just ordered solid mounts too. is the vibration real bad? i ordered the moroso ones on jegs.
Old Apr 10, 2010 | 10:42 AM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: engine mounts
i had the moroso solid mounts in my '85 t/a, and in my '91 camaro. i never had any problems in either car, and no they were not race cars. both engines were street driven re-builds, and i couldn't tell any difference in vibration with the rubber or the solid ones. the car twisted slightly more with the solid mounts when i revved it up, but completely tolerable. just have to make sure that you order the frame side mounts and the engine side mounts with the moroso mounts, they aren't sold together.
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
