truck 350 swap?
Old Oct 24, 2001 | 12:20 PM
dmair5_0's Avatar
Car: 91 Firebird
truck 350 swap?
Question for you all, if I want a 350 block, with the 350 TBI off a truck, can't I just pull a 350 out of a truck and make it work in my 91' Firebird? What else would I need? Would the wiring harness work from my LO3? New knock, and chip (from truck or custom burn?) I would probably add good heads, and cam. Someone tell me if this would work, or if anyone had sone it? I'm looking for the most straightforward swap possible. Thanks!
Old Oct 24, 2001 | 12:38 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
305 to 350 swap requires a minimum of three things:
Knock Sensor Part# 10456288
Knock Module Part# 16128261
and either (2)350 injectors Part# 17112493
or an adjustable fuel pressure regulator.(or both)
Custom chip is also a good idea.
If you change the cam,stay with an EFI profile,not too much duration.
-Rich-
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
xkingcodex
Feb 12, 2020 07:43 PM
bellez77
Sep 5, 2015 08:39 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
