a 1992 - 96 F- Body LT1 Engine
Old Oct 23, 2001 | 11:31 AM
Corvette0096's Avatar
How Will this fit in my 85 Vette? I want to use my tune port and dist, And what do i have to do about the optic spark on the front? This a simple swap?
Old Oct 23, 2001 | 12:56 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Hmm... if you got a TPI vette and a whole LT1 motor, the best thing would be get vette acessories im guessing and follow the guys instructions for modding the LT1 intake to accept a dist, the LT1 intake is far better than the TPI, but putting a dist would let you run your stock computer etc and remove the opti, the stock f body acessories may fit but im not sure, dont have a vette myself, you'll also need an LT1 radiator.
Old Oct 24, 2001 | 01:00 PM
mat89RS's Avatar
I would defenitly not go with a TPI on an lt1, this engine makes around 300 hp ...TPI can't feed a mild 350 ....if you want torque and hp keep the miniram and all of it's component, do a wiring harness yourself and it should take around 10 days if your alone and it's the first time your doing it.
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
db057
Jan 10, 2020 08:55 PM
1992Z28!
Nov 19, 2015 07:33 AM
Giocio
Oct 1, 2015 12:20 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
