Fixin to drop the LT1 in....but first a few Q's for the experienced....
Old Oct 19, 2001 | 12:05 AM
MM89Iroc's Avatar
I have a 96 LT1...trying to hook it up to a 700R4 tranny. I don't have hands on expierence with engine swaps and stuff so my friend is doing most of the work. We are wondering how do you hook the kick down and cruise cable to the 96 throttle body? Do we need to buy a 93 throttle body since it came with a 700r4? Or what?
The fuel lines are also a mistery. Do you guys know what fittings are required to adapt the old lines to the fuel rail on the LT1?
The A/C lines are also puzzling us. Have I heard correctly that you can use the "old" a/c lines from the 89 and rebend them to line up to the LT1 compressor? If not, what exactly do I need to do?
Sorry for all the questions, but we are trying to "get our ducks in a row" before the engine is set into the bay and everything gets confusing...
Thanks,
MM
Old Oct 19, 2001 | 04:16 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Well, I could help you on the TB question. Yes, you need the older throttle body for the TV cable provisions.
Old Oct 22, 2001 | 02:02 AM
MM89Iroc's Avatar
Thanks....Bttt
Old Oct 24, 2001 | 01:07 PM
mat89RS's Avatar
just use a flaring tool and redo the fuel line completly...that's what I what I did, about Ac i don't know, i'm not using it ...
LT1 POWERED
HEADMANS HEADERS
300 HP backed with a limited slip, 2.73.
Top speed reached: 150 mph
EATS MUSTANGS FOR BREAKFAST
Old Oct 24, 2001 | 09:53 PM
MM89Iroc's Avatar
mat89RS...
Do you mean cut the old fittings off and add to length and then put new fittings on that or what?
Thanks,
MM
Old Oct 24, 2001 | 10:34 PM
TexasLT1's Avatar
Car: '92 RS
Carquest has a 90 degree a/c adapter that allows you to keep the a/c. get some new hose from your parts store, and cut off the original fittings from your old hoses, but cut the hose away from the fitting, dont just whack off the very end. then, using the new hose, push the fitting into the end, secure it with a hose clamp or two, and the secure the other end to your compressor fitting. just make sure you hook the lines up in the right place, dont do it backwards like we did at first.
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
-'95 Camaro Z28
-'88 Firebird
-'99 Ford Lightning
Losses
-'01 Mustang GT
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
RedLeader289
May 28, 2019 01:47 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
sahlomonic
Sep 20, 2015 07:15 PM
