Read the sticky, 3.1 to carbed 305 Checklist
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
May have found a donor car, just making sure Im not forgetting anything...Ill need...
Carb, intake manifold, fuel pressure regulator, front springs...Anything else short of the long block Im forgetting?
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Re: Read the sticky, 3.1 to carbed 305 Checklist
EDIT
Dude I just read your build thread....Youve been around for awhile now - 2001 !!!! youve got it covered Bro.... Youve got a racecar for crying out loud!!!! what motor are you going with?
Hell I should be getting tips from you not giving them.....
Yeah, just wanted to make sure I wasnt forgetting anything. The engine is a tpi 305 that I will convert to a carb setup. Nothing too crazy, just something to putz around town in.
Transmission: 4L80E/4L80E
If you are getting a donor car, why are you converting it to carb?
I wouldn't wish a carburetor on my worst enemy. I've got one more Holley to sell and a CC Quadrajet I'll probably toss in the garbage can, then I'm out of the carburetor business forever. Fuel injection is lightyears easier to deal with. Thread
