How fast would a GTA350 with a new cam and carb intake be on a 84 TA??
Old Oct 29, 2001 | 11:23 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i might b able to get my hands on a GTA 350 for a good price and i was wondering if you guys would know how fast it would b if i put a better cam in it and swapped it from tpi to probably a edelbrock performer intake a edelbrock 650 carb
anybody do anything close to this?
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
Old Oct 29, 2001 | 11:35 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
You should be able to get into the mid 14s with a L98. The L98 has terrible flowing heads, so you really couldn't go with a much more aggressive cam, unless you work the heads some. You'll also need a new manifold for the carb. Other than that, the motor is a good 40-50 HP up from your L69.
Old Oct 30, 2001 | 09:01 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
mid 14's thats it!!!
man i thought i saw formula's runnin high 13's on pretty much the same motor
or is there a diff?
Old Oct 30, 2001 | 09:26 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
What rear end ratio do you have? You may be able to see high 13's with excellent traction and 3.73 gears. I've never seen a stock L98 go faster than a 14.5.
Old Oct 31, 2001 | 10:40 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well i wasnt really talking about a stock one
i was gonna put in a hi-po cam and intake and carb
and i have a single peel 3.73 rear
but im prolly gonna change to a 3.42 posi soon after i get whichever 350 i get
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 1, 2001 | 08:44 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
As long as you do some head work along with that cam, you might squeeze mid 13's out of it.
midge54
Dec 27, 2019 04:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
