383 swap for TPI
Old Oct 21, 2001 | 01:45 PM
Stroked-Z's Avatar
383 swap for TPI
Hi guys. I just bought an '87 Iroc(305 TPI w/ 700R4) & have my 383 that i took out of my old '81 Z-28. Now i want to put this 383 in my 3rd Gen & use the factory TPI that came with it.
I KNOW NOTHING OF TPI practically!
I know i will need bigger injectors(30#) and will need to open up the intake, a 350 knock sensor & a custom prom or so. I need to know if i can use my cam....let me give you my motor specs
-383 stroker & maybe Vortec 64cc heads(comp 11.5:1) They are .100 dome pistons
-COMP xe284(240/246 DUR@.050..... .507/.510 LIFT, 110 LSA)
NEED HELP!!!!!!!!!!
383 stroker, 11.5:1, Vortec heads, Comp XE284, Edelbrock RPM, MSD Distributor, Holley Strip Annihilator
Old Oct 21, 2001 | 05:43 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
1)you'll need to modify your intake or buy the one from scoggin-dickey to fit the vortec heads.2)those heads even when ported will hinder that combo with those ski slope lobes you got on that cam.3)over 240* @.050 is gonna play hell with the ecm(having a maf is a double edged sword).i would go with either trick flows or afr's and a cam similar to slp's large cam(224/230-will be easier to tune the prom)and either a superram or a well ported accel/as&m setup.24lb.hr injectors can support 400hp no need for 30's
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
[This message has been edited by PETE (edited October 21, 2001).]
Old Oct 21, 2001 | 10:30 PM
Stroked-Z's Avatar
anyone else try & help me out!!!!
Please!!!!!!!!
Old Oct 26, 2001 | 06:27 PM
jamesbern's Avatar
carb it like I am doing. It will save you a chunk of change.
Old Nov 2, 2001 | 02:45 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The stock TPI will choke your 383; if you want to build a stump-puller that tops off at 4000 RPM, you're OK, but if you're looking for more revs than that, you need a different induction system. Aftermarket runners and intake base, or something more radical will be required.
And Vortec heads can be ported to make a LOT of power. A local friend of mine had a pair on a 406 2nd gen. NA in the 12s, sprayed in the 11s. He's now running dart heads and is even faster, but the ported Vortec heads made a very fast car for him.
Old Nov 2, 2001 | 05:03 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I ran the stock tpi on my 383 with the stock chip and it ran 13.50's. Get a chip burned for that cam and run the stock tpi until you can afford something bigger or port the stock stuff. It will run out of breath around 4300 rpm.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
