350 TPI w/tranny how much is it worth
Old Oct 29, 2001 | 11:05 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Just like the topic says. What could I get for them. Thinking about buying a totaled car and to offset the cost looking into selling motor as I dont need it.
1990 Camaro RS
1991 Acura Integra LS
check out my site: <A HREF="http://www.geocities.com/joecool_2u" TARGET=_blank>
</A>
LT1 motor stuff so far:
TPIS ZZ-9 cam, Comp Cams 1.6 Roller Rockers, Comp Cams "R" Lifters, Crane Cams Dual Valvespring kit, Underdrive pulley, and an air foil.
383 LT1 Stroker project has begun.
Old Nov 5, 2001 | 10:30 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Around here, all the wrecked TPI cars (Camaros,Firebirds and Vettes)are picked up quickly by GM Sports Salvage in San Jose,CA.
They charge about $2000 for a TPI 350 w/700R4
trans! Admittedly , this is high, especially for what amounts to a core,but that's the going rate in the Silicon Valley!Horrifying isn't it? Unless you're the seller!
Anyway, it's obviously gonna depend on the going rate in your area,but I'd guess $500-800 (for a runner)to someone that didn't just fall off the turnip truck.
Rich
Old Nov 5, 2001 | 10:49 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yeah, I had the chance to buy a 350 tpi from a 90 formula with edelbrock heads, cam, motor work, and shift kit for 1000 bucks.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
