What starter to use on engine swap?
Old Nov 3, 2001 | 02:19 PM
fazool's Avatar
Ok, I tore out the tired 305 from my '86 firebird with 700R4 auto tranny. Built a new engine, and now I don't know what starter to put in.
The block is casting number 3970010 and it's a 350 4-bolt block. IDing the block shows it came from '69 to '79, in cars trucks and vettes. I noticed that the flex-plate included with the engine kit is about an inch larger in diameter that the factory original.
So now I know the original starter will not fit, but how do I figure out which is right? All the guys at the auto part store could do was say "give me an application, and we'll fine the starter". Yeah, right. Sounds like I have to keep trying starters until I find the right one. It would be much better to find the right one first try - second try worst case.
Anybody been down this path before and can give me some advice? And, how do I tell for sure that the one I get is right?
gene
Old Nov 3, 2001 | 07:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's possible that the starter for a vast number of cars, like all the ones with T-350s, would fit. The part # is 3510-S. Try that one and see if it will fit in the bell housing. It's the one that goes with the 14" (168 tooth) flex plate.
I seriously doubt you can put the right starter for a 153-tooth 12¾" flywheel on there. The inner bolt would have to go RIGHT THROUGH the starter drive. I have a 400, same exact issue, I drilled & tapped the block for the late-model starter pattern, which is what you'll have to do if the 3510 doesn't fit.
ICON Motorsports
Old Nov 5, 2001 | 08:11 AM
89 CamaroIROCZ's Avatar
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
If the engine is still out drill and tap the bolt. I went through taking the engine out twice before I finally got a flexplate/starter combination taht would work. I believe i have the bigger flywheel and a 250 dollar mini starter that would work by the end. It was a major Pain in the *** .
Matt
Old Nov 5, 2001 | 02:43 PM
ATOMonkey's Avatar
Get a new flexplate. It's not worth drilling and tapping. They're less than $40 at any salvage yard.
'89 Red Formula 350- 350 .060 over w/ forged pistons, 232* @ .050 cam, Performer RPM, Holley 750 DP, Vortec 1.94 1.50, Accel Coil and dist, Hedman shorty headers, Dual Exhaust w/ cutouts, WS6 suspension, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors, 700R4, A&A snorkel scoop Eclipse Head Unit, Delco Bose Speakers, 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Nov 5, 2001 | 06:46 PM
85TA377's Avatar
I am just now running into this problem. I built a 377 last year for my 85 TA and dropped it in. Next came our baby, which put the project on hold for a year. I am using a 74 400 block with the stock 85 flex plate and a built 700R4 trans. I didn't count the number of teeth the flex plate had on it until after I put it on. How many teeth does the stock flex plate have? The engine was a 305 TPI. Next, is the starter you recommend the same one that I need to try on this engine? Thanks for the input!
Chris
69 Firebird Conv
85 Trans Am w/377
94 Ram Air Trans Am
02 Collector Edition Conv (on the way...)
</font>
Old Nov 5, 2001 | 06:49 PM
fazool's Avatar
Ok now I'm really confused. Is it totally unlikely that I can get the big flex plate to mate up with a starter?
How can I tell when the starter is correct?
I'd hate to pull out the motor, but since it's not really connected yet, it's not too big a deal.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
