LG4 wiring question
Old Oct 31, 2001 | 03:27 PM
Big Money Mike's Avatar
LG4 wiring question
Alrighty!!! I started plugginf the harness into the engine bay last night and was wondering something. The plugs that hang out the bottom of the dash into the passenger side foot well that plug into the main harness, are those the wires that run the dash? OR... There is a seperate small harness that has wires running through the firewall into the cabin, are those the speedo and such wires?
Mike
Old Oct 31, 2001 | 11:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If I understand your question correctly, your first answer is correct.
There are some wires for lights and cruise going through the firewall on the driver's side, but the instrument wires (I'm pretty sure) are part of the harness on the passenger side.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ4 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (ported World 305 heads, Crane PowerMax cam, Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 2, 2001 | 12:44 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
on an LG4 All the wiring to the gauges comes through the firewall in front of the fuse box. Most of them are the same.
If the ones that plug into the ECM you are speaking of,they go to the Lamp driver, fuse block and ALDL, and the VSS signal from the back of the speedo.
anything past the consol to the pass door is either speakerwire or ECM.
If you disconnect the ECM, pull the kickpanel off the interior and feed the harness out into the fender, you can probably pull it right through. that's all the ECM wiring to the engine compartment, save one pink black powerwire for the ECM that comes across the engine compartment by the brake booster.
It's always SOMETHING
[This message has been edited by Pony Killer (edited November 02, 2001).]
Old Nov 5, 2001 | 11:09 AM
I cut the wires and plugs off the V6 harness to splice into the V8 one where the previous owner had chopped the plugs off. I guess I need to hook the wires together and plug it into the plugs that come from behind the dash and hang into the footwell.
Mike
Old Nov 8, 2001 | 12:56 AM
five7kid's Avatar
I just pulled the engine out this past weekend. Everything that went to the engine - oil, temp, tach, ignition power, CC carb connectors, CTS, TCC lockup, starter, etc., went with the engine harness that goes to the passenger side fender through the ECM connector.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4 (restalled TC). Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 8, 2001 | 08:22 AM
I wired the plugs from my V6 harness to the V8 harness the other night so that I had the plugs going from the main harness to the plugs that come out from behind the dash and connect to the main harness at the ECU. The deal is though, I could only mathc up about 5 of the wires, and there were probably 6-7 more that didnt match anything on the V8 main harness where the previous owner had chopped them off for some reason. I connected a black/white tan/white pink/black orange brown. i think thats about it. But there were more wires that didnt match up. I looked in my Chiltons and couldnt find what the 3 plugs coming from behind the dash into the footwell where for. Oh well, Im sure it will still run, I may have to rig up soome gauge connections if thats what the plugs are for.
Mike
RazorN8
Jan 7, 2022 11:44 AM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
