anyone ever hear of the LT-5 ?
<font face="Arial"><a href="http://www.geocities.com/battstas/cars/transams.html" target="_blank"><font size="2">Click here to see my Trans Ams</font></a>
<font size="1">1986 Trans Am WS6 (#40,977 of 48,870)- Silver, 305TPI, 16" charcoal gray cross-lace wheels. 175,500 miles, LB9, 700R4.</font></font>
<img src="http://www.fbody.com/members/98TransAm/86/1986.jpg" width="200" height="80">
<font face="Arial" size="2" color="#FF0000"><marquee width="201" height="18" scrollamount="3" bgcolor="#000000">CURRENTLY: the '86 was rear-ended in Austin (about 3K worth of damage), and is undergoing repairs. In other words... fighting with the insurance company of the guy who hit me </marquee></font>
<font face="Arial" size="1"><a href="http://www.fbody.com/members/98TransAm/DSC00037a.jpg">'98 Trans Am</a>- (#907 of 12,046)- 3.23 4A, Chrome Wheels. 68,700 miles. <a href="http://www.fbody.com/members/98TransAm/DSC00055ga.jpg">'99 Honda VFR800fi</a>- 6,500 miles, GIVI wind screen <a href="http://www.fbody.com/members/98TransAm/99rodeo1.jpg">'99 Isuzu Rodeo</a>- V6 2WD 29,000 miles. </font>
Car: '89 Firebird
Engine: 7.0L
You can buy a complete new crate motor with ALL accessories attached for about $12K. Not worth it in my mind for approximately 400-HP. However, the LT5 is a highly underutilized engine in terms of performance potential. The level of modifications over stock to pump out 700-Hp is minimal compared to other engines but the cost to do those mods is substantial.
Chevy had a showcar Camaro a few years back with the LT-5...they had to shoehorn thehell out of that thing to make it fit, then had to fab al kinds on intake ducting. They had to notch the members, and throw out the AC. Great motors developed by Lotus, and very expensive and underultilized as stated above.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah get out the check book..i saw one at carlisle a year back and it was 15 grand for a new one still in the crate.
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
-Brian
z28boy.cz28.com
Car: 1991 Camaro RS
-Brian
z28boy.cz28.com
-Brian
z28boy.cz28.com
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Chevy has that camaro on it's
legends tour.I've seen it in
mags but no I don't think any-
one has ever tested it.Nice idea
but you don't want to go there.
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I think you wanted to know what an LT5 is, right? It was an 350, aluminum block, 4-cam, 16 fuel injectors and it produced 375hp. They put these in about 6,000 ZR1 Corvettes(quiet collectable nowdays). It was a good idea for the time but the whole set-up is too expensive and hence it was abandoned.I read a comparison between the LS6 and the ZR1s LT5 in a magazine(GMHTP or SC,I forget) but the LT5 is old news, compared to the single cam LS6 V8 w/a slightly smaller displacement.
Although the ZR1/LT5 did have a cute feature.You can turn off 8 of the 16 fuel injectors with a "wallet key" thus rendering the car "powerless".I think it was like 225hp. Hey, just like a 3rdGen of those times! LOL.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners, March Power/Amp Pulleys, Richmond 4.10 gears. (???HP)
1990 Formula
Actually the later ones had 405 HP and they could run with Z06's and TwinTurbo Vettes.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
91 z-28 305 700R4
3.73 gears out back
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
I remember when I used to work at a dealership we had one of those C4 vettes. It had a switch on the dash that said 225hp on one side and 405hp on the other side. I think I about wet my pants when I saw that back in '94.
Car: '89 Firebird
Engine: 7.0L
This comparison is silly. The LT5 is a far superior engine to the LS6. It's seriously hampered in stock form and makes one serious power curve with very minor mods. Stock to stock tests are pointless. No performance oriented person is going to run stock. A street worthy modded N/A LS6 couldn't catch a street worthy modded LT5 on the best of days. However, as I said before those simple mods to the LT5 come with a great price tag.
I don't believe the LT5 shuts off fuel injectors for the valet mode. That would cause it to run lean. It restricts the air flow to the engine with valves in the runners. In valet mode only one set of valves is open. In power mode both sets of valves are open.
[This message has been edited by QwkTrip (edited October 31, 2001).]
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
<font face="Verdana, Arial" size="2">Originally posted by QwkTrip:
[This message has been edited by QwkTrip (edited October 31, 2001).]</font>
I used to frequent ZR1.com when I was considering purchasing a 94 ZR1.
Now I've got the MKIV Supra bug, I want one sooo bad.........too many choices, not enough money.
WS6 Trans Am.
View My Ride @ thirdgen.org
Car: '89 Firebird
Engine: 7.0L
It might be a combination of both. We've taken the manifold off my friend's ZR1 to change the starter and enlarge the drain passage. Seemed at the time there were valves that restricted air flow.
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
LT5 5.7Lt V8 Quad Cam 32 Valve multistage induction 405 HP. The LT5 has an incredible 11 throttle plates!!!
What more do you want? Gotta Luv those ZR-1s
Rob
Rob
If Chev had kept with the LT5 design imagine how much power it would probally be making now. The Viper would have to be playing catch-up with the Vette rather then the other way around. 10 years of tech development goes a long long way.
i was thinking about LT5 too....
boner.......... lol... im going LT1 with Lt4 swap over stuff i do believe,
what would a Lt1 with SLP headers, ,high flo cat, edelbrock xaust, ,upgraded fuel pump, and Wires, hit around?HP wise,
and then throw on LT4 heads with Lt4 cam, and ignition? whats your imput?
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
|--|what would a Lt1 with SLP headers, ,high flo cat, edelbrock xaust, ,upgraded fuel pump, and Wires, hit around?HP wise,
91 FireBird 305 V-8
"Honda's FOR ME TO POOP ON!" -Triumph... Supreme Member
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have a pic of a guys intake that blew up. He was running Nitrous and all of a sudden he had no power. He pulls off the road, pops the hood and sees that the center of the manifold has split on 3 sides. It looks like a backwards air scoop. It apparently still ran (with a rather large vacuum leak
) Its an awsome.. but heart breaking pick. Those things are impressive.
) Its an awsome.. but heart breaking pick. Those things are impressive. Thread
sjorgens
Oct 1, 2015 07:54 PM
