IS THIS TRUE?!!?
IS THIS TRUE?!!?
I've heard that V8 cars were made better? I'm talking about the body. Were they made for rigid? And no, this shouldn't be in body and interior. Thanks. Is there ANYTHING beside the springs and mounts etc, that are different? Like the frame or anything? Thanks.
"better" is pretty subjective and hard to quantify isn't it? better for what? naturally a iroc, ws6, or z28 would have heavier suspension parts and the convertables have a sort of factory SFC. the v8 cars will make more power than a v6.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
I mean, were v6 cars made for a v6. And were v8 cars made for a V8? See what I mean? is the body of a v8 car stronger than a v6 car? Visa Versa? See what I mean? Okay, is a 84 trans am the same body as a SE? See. Same suspension? etc. Does that make sense?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Other than suspension components, the body of the cars are identical. As mentioned above, T-top cars and convertibles were made a little bit stiffer but other than that, they're all the same.
V8's got heavier springs depending on the model. WS6 and IROC's also got bigger sway bars.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
