Machining for a roller cam
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Nevermind, i forgot that i needed a 1 peice rear main seal.
[This message has been edited by Omega (edited November 13, 2001).]
Transmission: 4L80E/4L80E
I didn't see your original question, but be forewarned - not all 1-piece rear main blocks are set up for a roller cam. My '86, for instance, has a 1-piece rear main and absolutely no provisions for a roller lifter cam. Same occured in later years for truck 350s (some had casting provisions but machining not done).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: `86 SS / `87 SS
Right: 86 blocks are not setup for an OEM roller cam.
87 up truck (and some passenger) blocks that aren't originally made roller only need the 3 nipples in the valley tapped for the spider retainer bolts, and whatever timing set mods... The block's valley is already setup for the anti lifter spin retainers by a flat surface.
jmd
1986 SS with...
86LB9 TPI atop the original L69, Hooker emissions legal PN 2050 headers, stock L69 cat (yes, a real one), hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
jmd
1986 SS with...
Engine: LS1 / LS3
Isn't it expensive to get a roller cam for a non roller engine? ... is the cam selection any good for that.
Engine: LS1 / LS3
I found a block from a 90 caprice.. are these 1 piece w/ a roller? The guy couldn't be bothered to get the casting number for me.
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
90 Caprice is suppose to be a roller motor. Will definitely have provisions for it.
Engine: LS1 / LS3
Thanks everyone i think i am getting the hang of the major differences between blocks. Now i need to find a way to get this home.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
