engine comparo
Old Nov 16, 2001 | 08:53 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
engine comparo
Im looking 4 a 400 sb, or a 350 4 bolt
What is the main diffrence ?
im looking 4 power until 7000rpm max
is forged necessary? (crank)
Old Nov 20, 2001 | 04:05 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Niether can get you to 7000 keeping it streetable. A 350 is good to around 6000 with a smooth idle, and not too much matenance. You don't need a four bolt either. You'll do just fine with a two bolt. In fact, you won't even be able to tell the difference. You won't be putting enough power out to twist the two bolt.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
