Aluminum or Cast Iron Heads?
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Hey,
This may sound dumb but...
I was looking the another day to get a new set of AC Delco Rpaid Fire Plugs for my 87 Iroc (5.7L). The problem is that the cross reference book gave two numbers for the plugs...one for aluminum heads and the other for cast iron heads. How do I know what kind I have??
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Check out my ride in the Readers Rides
https://www.thirdgen.org/rides/index...ew&rideid=6920
Better to look at it than to look for it
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Ok...I will have to do that the next time I get check my car out (its stored and the place is not readily accessible)..
So as another question... which heads are better? Aluminum or Cast Iron?
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
1987 Camaro Iroc Z
T-Tops
Maui Medium Blue
5.7 L TPI
TH-700R-4 Tranny
Dynomax Super Turbo
Removed Cat
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
For long life in a street engine, cast iron. Aluminum heads disipate heat better and can run at higher compression ratios. They are lighter than cast iron. The downside of aluminum heads on a street car is that the aluminum corrodes from poor coolent mixtures and with the constant cooling and heating of the engine they will eventually warp. Aluminum heads are available on a few engines from the factory but are mainly produced for the performance enthuesiest. I doubt you would find aluminum heads on a street car that has 200,000 miles on it.
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I'm sure that there are plenty of 200k mile aluminum headed cars out there; probably even plenty of LT1s. LOTS of 4 cylinder engines run aluminum heads and are just fine.
Car: Death Mobile
Engine: 666 c.i.
<font face="Verdana, Arial" size="2">Originally posted by MorgRS:
Duh...Mercedes have been using them for decades..</font>
It has been my experience on the various vehicles and engines that I've owned that had aluminum heads, tended to need rebuilds much sooner than iron heads. The good aluminum heads were always "rebuildable". But I can see how a poorer designed aluminum head might not be due to warpage.
What I've always hated about aluminum heads is "cross-threading", especially the spark plugs. I've had few of those too in my life time.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
