sbc torque specs
Old Mar 1, 2010 | 10:53 PM
RedRokkit's Avatar
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
sbc torque specs
Just figured Id post these up.
These specs are for stock bolts, if you are using aftermarket bolts
you should follow their recommended specifications.
Format: Fastener...apply to threads...Torque Rating
7/16 Main Caps (2 bolt) Engine Oil 70 ft-lbs.
7/16 Inner Main Caps (4 bolt) Engine Oil 70 ft-lbs.
7/16 Outer Main Caps (4 bolt) Engine Oil 65 ft-lbs.
3/8 Outer Main Caps (4 bolt) Engine Oil 40 ft-lbs.
3/8 Connecting Rod Bolt Engine Oil 45 ft-lbs.
11/32 Connecting Rod Bolt Engine Oil 45 ft-lbs.
Cylinder Heads Engine oil (blind hole) or Sealer(water jacket) 65 ft-lbs.
Rocker Studs (screw-in) Engine Oil 50 ft-lbs.
Oil Pump Engine Oil 65 ft-lbs.
Oil Pan Engine Oil 12 ft-lbs.
Cam Sprocket (upper gear) Thread Locker 20 ft-lbs.
Timing Cover Engine Oil 6 ft-lbs.
Intake Manifold(Cast Iron Heads) Non- Hardening Sealer 30 ft-lbs.
Valve Cover Engine Oil 3 ft-lbs.
Exhaust Manifold Anti-Seize Lubricant 25 ft-lbs.
Spark Plugs No Lube or Sealer 20 ft-lbs.
Flexplate (Automatic) or Flywheel (Clutch) Thread Locker 60 ft-lbs.
Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt(Harmonic Damper) Engine Oil 60 ft-lbs.
Bellhousing(Transmission to Block) Engine Oil 25 ft-lbs.
Old Sep 23, 2010 | 11:11 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: sbc torque specs
http://boxwrench.net/specs/chevy_sb.htm
Link to source. Plus other info.
codeysabatini
Nov 10, 2015 04:07 PM
89newfun
Sep 16, 2015 09:28 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
Ragtop Man
Sep 12, 2015 12:23 AM
angel2794
Sep 8, 2015 06:22 PM
