Quick starter motor question
Old Nov 26, 2001 | 10:40 PM
fazool's Avatar
I swapped out the 305 for a 350 in my '86 bird, took lots of photos for reference, but don't have one for the starter motor. I have put a 3510 starter into the engine, it has 3 terminals : S, R and the big center one. The wiring harness got labeled during disassembly, but I don't seem to have an exact match.
There are 4 wires. 2 of the wires are connected together to a single lug that is large enough for the big center bolt. Each of these wires has what appears to be a 16 Amp fusable link, making me certain that it goes to the large battery bolt. There's another red (maybe orange) wire with a 20A fusable link and also a large lug - I figure that goes to the battery connector too. This leaves one smaller, purple wire, with a smaller lug that could go onto either the S or R post - I just don't know which one.
Any help? If I connect the purple wire to either the S or R, that will leave the other lug without a connection. Is that ok?
thanks
gene
Old Nov 27, 2001 | 05:43 AM
scauffiel's Avatar
I'm pretty sure you connect it to the S terminal as that is for the starter switch. The R is for old points style systems. Of course this is all "If I recall correctly"
Steve
Steve's Trans Am Temple
Old Nov 27, 2001 | 08:18 AM
bhaas's Avatar
That is correct. The R terminal isn't used.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
Old Nov 27, 2001 | 09:42 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"R" stands for "resistor". Back in the old days (pre-'75), with the old points distributors, there was a resister in the ignition circuit to drop the voltage down to 6 volts to reduce points wear. However, to make it start easier, they used the solenoid to provide 12 volts to the coil while cranking. That's what the "R" terminal is for.
Many aftermarket suppliers will make one solenoid to cover many applications. So, like they said, ignore it.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 28, 2001 | 01:10 PM
fazool's Avatar
Thanks all for the help. Good advice, as usual.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
L98GTA87
Aug 5, 2015 11:02 PM
