Camaro 305 TBI motor in TBI S10 Blazer?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
OK, this is the first time I've posted a new topic, but I need some info on this swap.
I Recently replaced my 305 92 RS motor with a 350.What I'd like to do is throw some rings and bearings in the 305 (maybe a cam, too) and stuff it into my 91 S10 2WD 4Door Blazer.
It currently has a 4.3 V6 with TBI and
all the TBI connections look very similar to me and from what I've read, the Camaro's exhaust manifolds are the easiest fit in the Blazer.Will the wire harness and computer work with the V8?I'm hoping I can get away with just the adapter/mounts and a new chip.Has anybody done this?
Thanks in advance.
Rich
Thanks in advance.
Rich
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I plan on doing a similar swap. Check and see what the ECU service no is. I am believe it will have the 1227747 as the service no. If so you can plug all the sensors into the existing harness and just buy a chip from the dealer for a full size 1990 Chevy truck with a 305. Should make for a nice S10. Get an LT1 or L98 roller cam and spice that 305 up a little and make a very nice S10.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***getting ready for new engine. TBI version of this http://www.airflowresearch.com/Articles/A3-P1.htm
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
