best place/person to get tips for swappin a 305-350
Old Dec 5, 2001 | 10:31 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
im gonna b swappin my motor this summer and i wanna get a head start on how to do it
i wanna rip out all the smog crap and the computer stuff
thanks
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph W/O mods
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
5% tint all the way around
black light interior neons
Old Dec 6, 2001 | 05:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Start looking over the posts on this forum.
If you don't find the answers to your questions, you aren't looking hard enough.
Go ahead and ask after you've looked, though.
P.S.: If you look hard enough, you'll see the hair rise on the back of my neck when people talk about the need to "rip out all the smog crap and the computer stuff", though. That info can be found on the carb, exhaust, and tech forums as well as this one.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 8, 2001 | 02:41 PM
toosloz's Avatar
what exactly do you wanna do with your car?
thats what you need to think about
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 9, 2001 | 12:19 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
i wanna make it a daily driver that runs 13's and doesnt get HORRIBLE gas mileage
i've pretty much made the parts list for the whole deal
all i need now is what to do if i get stuck when im doin the swap
Old Dec 9, 2001 | 12:30 AM
five7kid's Avatar
"Daily driver".
"Runs 13's".
"Doesn't get horrible gas mileage".
Sounds like a 350 TPI with induction and exhaust upgrades and a nice shot of nitrous.
Meaning you keep "all the smog crap and the computer stuff".
You might also be able to do it with a 350 or 383 under the L69 equipment, with exhaust upgrades and that shot of nitrous.
Old Dec 9, 2001 | 02:15 AM
toosloz's Avatar
what i have is pretty much sorta what you are looking at, i do drive mine everyday, its is close to 13s and if i keep out of the gas...its is ok on gas
i am thinking mine would have hit 13.9 but i had trouble cooling it down and was running at 230 degrees constantly...i tracked my problem down to a bad "new" thermostat and bad rad cap...with the things i add this spring i am hoping for atleast a 13.6 if thats to much to ask...lol
84z28HO
355 9:5:1
open element/k&n
polished hurst "t" handle and shifter arm
10bolt w/3:42posi
performer intake
msd6al/blaster 2 coil
msd hei dust cap
accel 8mm wires
180 stat
gta rims
gts blackouts
s.s panhard rod
95 camaro rear view mirror w/ maplights
"wonderbar"
4th gen z28 tips
14.3@95mph
soon to come....hooker catback,slp headers, performer rpm intake and 750 carb and eibach springs/kyb struts
[This message has been edited by toosloz (edited December 09, 2001).]
Old Dec 9, 2001 | 07:18 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I'm building up a 355 for my 84Z28 HO car and am going to keep the CC carb and distributor. As the pollution control stuff went bad I took it off.
There have been several positive comments on this board about the CC carb doing a good job on the 350+ engines.
Craig
84 Z28 305HO, 5spd, 222,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter, 14.630 at 93.17mph
Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts, AU secondary rods
www.indycamaro.com
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Giocio
Oct 1, 2015 12:20 PM
Night rider327
Sep 25, 2015 04:47 AM
