I blew up my engine! What should i replace it with?
This sux, i threw a rod and might have cracked a piston in my 87 2.8L RS. The car itself in almost perfect condidtion so i will be keeping it. I was thinking about about dropping in a 3.4 but since i have to replace the engine anyways i figure i might as well just spend the extra cash and drop in a 350. Good idea or no?
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by a73camaro:
Don't forget
Stronger tranny</font>
Don't forget
<font face="Verdana, Arial" size="2">Stronger differental</font>
<font face="Verdana, Arial" size="2">Brackets and acc. for the new engine</font>
<font face="Verdana, Arial" size="2">Drive shaft, shifter, </font>
<font face="Verdana, Arial" size="2">motor mounts.
Starts adding up in a HURRY!</font>
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited December 13, 2001).]
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I agree with 57kid. Sell car and buy a V8 car. Or part out car and scrap the rest. You will be much happier if you start out with a TPI car which can be had for $3k or less. Replacing tranny and getting posi will cost you a $1k + engine and headaches and other misc crap that always comes up.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
since you like the car alot, keep it. Compare prices between used 2.8/3.1/3.4 motors. Make sure they are all from 85-95 camaro/firebirds. 3.4 should not be more than $750 for a low milage motor. just swap over the exhaust manifolds, starter, accessories, intake manifolds, etc....
When the hood is popped people see 2.8, not 3.4
$150.00 2.8 Auto.
short block now
turbo eventually, 3.4 may be in the future
76 Bonnie: 400/400 CIA/Ram Air w/ metal clothes dryer ducting
Power "boat"ing land style
Giving the enemy the opportunity to die for their country
$150.00 2.8 Auto.
short block now
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since the chance of finding a V8 car in as good of condition as your V6 may be slim, selling the V6 car for a V8 isn't a good option. To get everything you need to convert to a V8 still means finding a V8 car though. Then once you have everything required, swap all the V8 stuff into the V6 body.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
