85' 305 to 89' 305
Old Mar 11, 2010 | 02:20 AM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
85' 305 to 89' 305
I have a 1985 305 TPI in my iroc... I currently have a 1989 305 longblock on the stand. Will the tpi off the 85 fit on to the 89' block?
Someone told me that the intake was changed in 87.
If it wont just bolt on what would I need to make it work?
Hey thanks guys
Old Mar 11, 2010 | 01:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The "change" was to the center two mount bolts on each side being at 72 degrees instead of 90 degrees like the rest. You can either modify those bolt holes in the TPI base, or I'm sure you'll find someone willing to trade their newer base for your older base.
Or, use this opportunity to upgrade the base and choose the later style.
(By the way, it's the heads, not the block, that changed in '87. Well, the block changed, too, but not in any way to affect the way the TPI mounts.)
Old Mar 11, 2010 | 02:00 PM
Weffy's Avatar
Re: 85' 305 to 89' 305
Yeah, the block changed to accommodate roller cams and roller lifters, the heads have center bolt valve covers. How hard would it be to modify the old base? Just drill 2 holes and its good?
Old Mar 11, 2010 | 03:03 PM
five7kid's Avatar
More like elongate the holes.
Center bolt valve covers came at the same time, but are irrelevant as far as bolting on the base.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
